Tagged: #anysys-#licences, academic-license, licensing, licensing-pool
December 16, 2022 at 10:32 am
Pawel11125
SubscriberHello,
I want to use Lumerical FDTD. I downloaded the program from lumerical.com (evaluate for free). I installed Ansys Optics 2022 R2.4 and Ansys License Management Center (latest version). Then I tried activate license but I had problem with that. I read in Ansys Quick Start Licensing Guide on page 6 that if I am a new customer and I did not receive a license file, I have to send you file with hostid to create a license for me. I sent this file but I received a message that I should write here with that problem. What can I do with that problem?
December 16, 2022 at 10:34 pm
Lito Yap
Ansys Employee@Pawel11125,
You are on the right track. To request for the 30 day evaluation license please follow the Knowledge Base (KB) guide:
How to request a 30-day evaluation license – Ansys Optics
- request for the trial license from the Lumerical simulation software.
- Add/install the license file you received into the Ansys LM on our computer.
- Restart Lumerical and configure this to obtain the license from the Ansys LM on server: localhost.
December 20, 2022 at 10:02 am
Pawel11125
SubscriberI've tried this tutorial and I have still this problem. But I've tried use another part of Lumerical ( MODE example Arrayed waveguide grating ) and I did it and I have license for this part.
December 20, 2022 at 6:20 pm
Lito Yap
Ansys Employee -
December 21, 2022 at 9:49 am
December 21, 2022 at 5:47 pm
Lito Yap
Ansys EmployeePlease contact the email provided in the Launcher using your institution's email that you registered with Lumerical.
>>> How to create or update your Ansys Lumerical user account – Ansys Optics
Free email/web based email (gmail, yahoo, etc) are not supported and will not work with our evaluation license.
January 10, 2023 at 11:45 am
Pawel11125
SubscriberI did everything like here, and I send email to support. They wrote to me that I should try to write on this forum.
I am from Wrocław University of Science and Technology so I have email from this institution.
January 10, 2023 at 9:08 pm
Lito Yap
Please try to request for the Ansys Lumerical FDTD license again. Let me know if you run into the same issue.
- Error on Lumerical device
2612
2088
1321
1108
459
