Problem with Mesh Interface in Setup
    • Tahywo
      I am trying to check for the temperature distribution of tubes in a cylindrical shaped thermal shield. Because of the complexity of the geometry, I am presently looking at the two tubes at the base plate. I am having an issue with the mesh interface at the setup, also it was showing an error (Error: 0nquire-adjacent-threads: not a face thread - Error Object: #) after opening set up.
      Anyone experienced something similar or with an idea on how to go about this? your help will be highly appreciated.
    • raul.raghav
      Could you attach your workbench archive file so we could take a look into it? If you're not sure how to create and share a workbench archive file, please refer: Saving & sharing of Working project files in .wbpz format
    • Tahywo
      Thank you Raul.
      Please find attached.
    • Tahywo
      Also I am getting this; (Error: floating point exception Error Object: #f) error while running my simulation.
      Any idea why that is?
      Also I am getting this error
    • Vishal Ganore
      You have bodies in surface contact with each other. Please use shared topology option as shown below:
      You also need to work on meshing each part. Apply suitable mesh type and size to achieve good mesh. Default mesh option will not produce good mesh for your application.
    • Tahywo
      Thank you Vishal. Will try this out.
Viewing 5 reply threads
