Preprocessing
Preprocessing
Problem with mesh
    • Bettysittel
      I need to refine mesh in the geometry Im working on, but it comes to default when I edit the sizing ! can anywone help me to fix this problem please !!
      Please can you post some images. In meshing there are sizes and also size functions: it's very possible for the size function to give a size that's finer than the default and finer than the other values you've tried.
    • Keyur Kanade
      Please insert some images. Are you using mechanical or CFD?
      Please check global sizing given. Please press 'enter' after giving size in the panel.
