January 18, 2023 at 12:49 pm
William
SubscriberI am attempting to Simulate a ring-shaped Coil with a Conductor going through the middle. I am looking for the mutual inductance between this conductor and the coil winding. However I am often getting an Error in calculating the conduction paths saying that the mesh of the source conductor is wrong. What I'm seeing is gaps in the Mesh of the winding terminal. (see attached screenshot)
I don't know how to refine the mesh in a way that this doesn't happen and I really don't understand why the Mesher just gives up on keeping everything connected.
January 26, 2023 at 1:36 pm
Moritz Hafkemeyer
SubscriberDid you find a solution?
I think I have a similar problem :(
My Problem: Help request: Unexplainable error in calculating the conduction paths (ansys.com)
January 27, 2023 at 8:28 am
- Maxwell, HFSS or Q3D?
- Error
2688
2138
1355
1136
462
