April 20, 2023 at 11:08 am
April 20, 2023 at 6:13 pm
Guilin Sun
Ansys EmployeeMaybe because you did not name the expansion monitor but you selected "mode_expanion". Please try instead of "select", set its name to be "mode_expansion" and see if it works.
April 27, 2023 at 10:19 am
David trop
SubscriberHey , TNX for the respones but it didnt worked
It shows that the next command is the problematic like it cant find the monitor even that I named it as I showed in the top of the picture
May 1, 2023 at 4:06 pm
Guilin Sun
Ansys EmployeeSorry to reply you late as I was out of office last week.
Did you set the name for the expansion monittor? the error masseage says that "in setexpansion, no expansion monitors are selected". Please set the expansion monitor name, and see if the error message shows again.
BTW: It is better to use port. and follow the online example.
You can gradually modify the online example to your design by change one object at a time and check which object causes the issue.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5412
3383
2471
1310
1022
