December 2, 2020 at 9:08 pm
nmontalbetti
SubscriberHello, I'm having trouble defining a volumetric reaction function while using the multiphase model.
Accoding to Fluent's User's Guide, the proper way of defining a reaction while using the VOF multiphase model is to do it through "Phase Interactions". However, when I "Phase Interactions" tab and select "Reactions", I can define the reactants and products, but I can't choose a Reaction Rate Function, the only option is "none".
The only models turned on in this simulation are the multiphase model and the species model. I'm modelling a microreactor and I've already ran simulations with just the VOF model activated with no problems.
This problem has occured both in Fluent 18.2 and 20.2.
January 11, 2021 at 4:32 pmSurya Deb
Ansys EmployeeHello, nOne probable reason for this is that a single energy equation is being solved [for both phases] for VOF and Mixture models. Whereas the full Eulerian-Eulerian model solves for separate energy equations for each phase. So for VOF and Mixture models, only a single temperature is available in each cell.nRegards,nSuryaViewing 1 reply thread- The topic ‘Problem with Multiphase and Reaction model interactions’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
