July 7, 2019 at 2:48 pm
Mohaemd81
Subscriberi had designed a radiator for cooling purpose but after making a named selection and chose inlet and outlet, all thing is going well until going with mesh I can't complete it and this message appears to me...
(One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. However, meshing might be successful on the other entities.) -
July 9, 2019 at 10:07 am
Ansys EmployeeHow close is the radiator surface to the outer domain face? How does that compare to the minimum cell size?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3720
2570
1783
1236
594
