Ansys Free Student Software
Problem with running Workbench
    • BoniekGD
      Hello
      I've already installed ansys fluent and i have a this problem:
      An unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
      --- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
      --- System.Exception: SceneGraph.Engine - failed to boot up.
         w Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
         w Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)
         w Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
         w Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
      --- System.IO.FileNotFoundException: Nie mo?na za?adowa? pliku lub zestawu 'Ans.Addins.Infrastructure, Version=19.4.0.0, Culture=neutral, PublicKeyToken=null' lub jednej z jego zale?no?ci. Nie mo?na odnale?? okre?lonego pliku.
      Fusion log:
      OSTRZE?ENIE: rejestrowanie informacji o powi?zaniach zestawów jest wy??czone.
      Aby w??czy? rejestrowanie b??dów powi?za? zestawów, ustaw warto?? rejestru [HKLMSoftwareMicrosoftFusion!EnableLog] (DWORD) równ? 1.
      Uwaga: z w??czeniem rejestrowania b??dów powi?za? zestawów wi??e si? pewien spadek wydajno?ci.
      Aby wy??czy? t? funkcj?, usu? warto?? rejestru [HKLMSoftwareMicrosoftFusion!EnableLog].
      Call stack:
         w ACP.Addin.Load(AddinLoadContext context)
      --- Ansys.Core.Commands.UserReadableFailureException: The addin Ansys.ACT.WorkBench.Addin could not be loaded, as the assembly C:Program FilesANSYS IncANSYS Studentv194Addins/ACT/bin/Win64/Ansys.ACT.WorkBench.dll does not exist.
      --- Ansys.Core.Commands.UserReadableFailureException: The addin Ansys.ANSYS.Core.Addin could not be loaded, as the assembly C:Program FilesANSYS IncANSYS Studentv194Addins/ANSYS/bin/Win64//Ans.ANSYS.Core.dll does not exist.
      --- Ansys.Core.Commands.UserReadableFailureException: The addin Ansys.ANSYS.GUI.Addin could not be loaded, as the assembly C:Program FilesANSYS IncANSYS Studentv194Addins/ANSYS/bin/Win64//Ans.ANSYS.GUI.dll does not exist.
      --- Ansys.Core.Commands.UserReadableFailureException: The addin Ansys.AQWA.CoreAddin could not be loaded, as the assembly C:Program FilesANSYS IncANSYS Studentv194Addins/AQWA/bin/Win64//Ans.AQWA.Core.dll does not exist.
    • tsiriaks
      Do you have C:Program FilesANSYS IncANSYS Studentinstall.err file ?
      If not, try setting your systems language to be English. Also make sure your username contains only English letters and numbers
    • BoniekGD
      I dont have this file but I have install.id file
      I've done it and still dont work. Maybe I have to reinstall system.
    • tsiriaks
      Can you re-post the error message again when you tried with English language and English user account ?
    • BoniekGD
         at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
         at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)
         at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
         at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
      --- System.IO.FileNotFoundException: Could not load file or assembly 'Ans.Addins.Infrastructure, Version=19.4.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
      Fusion log:
      WRN: Assembly binding logging is turned OFF.
      To enable assembly bind failure logging, set the registry value [HKLMSoftwareMicrosoftFusion!EnableLog] (DWORD) to 1.
      Note: There is some performance penalty associated with assembly bind failure logging.
      To turn this feature off, remove the registry value [HKLMSoftwareMicrosoftFusion!EnableLog].
      Call stack:
         at ACP.Addin.Load(AddinLoadContext context)
    • tsiriaks
      Thank you.
      Please also post the output of the following commands from CMD Prompt
      dir /s "C:Program FilesANSYS IncANSYS Studentv194*Ans.Addins.Infrastructure*"
      dir /s "C:Program FilesANSYS IncANSYS Studentv194Addins*Ans.A*"
    • BoniekGD
      I think that is not this but I can't find file which is named like Ans.A.......
    • tsiriaks
      You are missing a lot of files. Please try reinstall while using English language and this user account. Make sure you completely remove 'ANSYS Inc' folder before installing a new one.
    • BoniekGD
      I've installed english version of Windows and Ansys works.
    • tsiriaks
      That's great to hear !
      Thank you for the confirmation.
      Could you mark this thread as 'Resolved'   ('Is Solution') , so we know this has a resolution ?
      Thanks,
      Win
Viewing 9 reply threads
