February 16, 2022 at 2:32 am
zarakhai
SubscriberHi. I am doing linear motor but facing problem with same vertex for the begin and end of the face in transient. how do i need to do to solve this problems?
February 18, 2022 at 8:16 pmHDLI
1). Could you create an inner band to cover the all the moving objects ? This inner band is just cover the objects and smaller than Band.
2). Could you check the boundaries and see if it has any issues ? How many boundaries?
3). What is the solution type and is it "Cylindrical about Z" in 2D Maxwell?
HDLI
- Maxwell, HFSS or Q3D?
- Error
3694
2564
1765
1236
592
