Problem with saturation pressure udf for mixture flow
    • pavankonchada123
      When I try to use below mentioned udf at interface of water and watervapor/air mixture for saturation pressure it is giving floating point exception
      #include "udf.h"
      #define MOLAR_MASS_WATER 18.01534 //g/mol
      #define MOLAR_MASS_AIR 28.97 // g/mol
      #define RHO_WV 0.5542 // kg/m3
      #define RHO_AIR 1.225 // kg/m3
      DEFINE_PROPERTY(saturation_pressure,c,t)
      real z,sat_p,p_w;
      real vapor_p;
      //#!RP_HOST
      real vol = C_VOLUME(c, t);
      real temp = C_T(c,t);//300K
      real p_op = RP_Get_Real ("operating-pressure");
      Thread *pt = THREAD_SUB_THREAD(t, 0); // Primary phase thread
      Thread *st = THREAD_SUB_THREAD(t, 1); // Secondary phase thread
      // Get the volume fraction of both phases
      real vf_p = C_VOF(c, pt);
      real vf_s = 1 - vf_p;
      real rho_s = C_R(c, st);
      //vapor_p = static_p + operating_p; // absolute pressure = static pressure + operating pressure
      z=8.07131-(1730.63/((temp-273.15)+233.426));
      sat_p = pow(10,z)*133; // Pressure in Pa to mmHg (Yaws 35320pa
      if (vf_p == 1)
      p_w = sat_p + p_op;
      // If primary phase or mixture of phases
      else
      // Find the partial pressure of water vapour
      // partial pressure = cell pressure * water mole fraction
      // mass of primary phase in cell
      real m_sec = rho_s * vol * vf_s;
      // mass of water vapour and air in cell
      real m_wv = C_YI(c, st, 0) * m_sec;
      real m_air = m_sec - m_wv;
      // No of moles in water vapour and air
      real N_wv = m_wv / MOLAR_MASS_WATER;
      real N_air = m_air / MOLAR_MASS_AIR;
      real N_total = N_wv + N_air;
      // water vapour partial pressure
      p_w = (sat_p+ p_op)* (N_wv / N_total);
      //Message("Pressure %f %f %f ",p_w,sat_p,(N_wv / N_total));
      //#endif
      return p_w;
      As a general tip, set all the real definitions at the top, don't scatter them through the code. Also note that Fluent will return SI units only, so check the equations are in kmol etc. Due to some Americanisms creeping into the software a kgmol is a kmol, which can cause some confusion.
