3D Design
3D Design
problem with spaceclaim
    • bxddstl
      Professor, ,I am a novice. I have a qusetion .
        I am currently using Space Claim for modeling, and I find that this software will cause my computer to stall(I mean the software run too slow) when modeling large objects (only large in size, but not complicated in shape). Is it because I don't have enough RAM?My RAM is 16GB.
        In addition, I would like to ask if SpaceClaim has the function of using one object as A reference to move another object. Similar to SolidWorks, I can use object A as A reference and move B to make B 3 meters away from A.
       Thank you for your help.😀
    • 1shan
      Have at the image below. Use the move option, select the body you wish to move and set an 'anchor' with respect to which you want the mobile body to move.
      Regarding the first part of your question I am not sure but 16GB should be enough for running space claim without issues, the problem is something else. Have a look at https://www.cfd-online.com/Forums/ansys/79866-very-slow-response-designmodeler-ansys-workbench-2-0-a.html.
      Regards Ishan.
    • bxddstl
      Thank you very much, sir.I got it.
