November 2, 2023 at 6:33 pm
javat33489
SubscriberHi all.
I enabled the ELOUT_DATABASE entry in ASCII:
The elout file is created, but no writing is done to it, why? Also I don't see any binary file binout000 created. I need this for fatigue analysis.
I thought that there were no initial values and added two cards:
But it did not help.
Elout file is empty:
Why?
Thank you.
November 3, 2023 at 1:05 pm
Alex R.
Ansys EmployeeHi,
To enable binary files you should chage BINARY flag to 3 in ELOUT_DATABASE. ELOUT_DATABASE only specifies the frequency that element data will be printed. You still need to specify which elements your ELOUT_DATABSE should include. To do that, please refer to the LS-DYNA User Manual VOL I and look at *DATABASE_HISTORY_OPTION.
Alex
November 3, 2023 at 3:28 pm
javat33489
SubscriberYes, I figured it out. I'm using HISTORY_SOLID_SET. Now the recording is on.
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3153
1680
1470
