February 15, 2022 at 3:37 am
zarakhai
SubscriberHi. I have problem with the output waveform. There is no error but no moving position-time waveform produce for for my linear motor. Do help me in for this problem. thanks
February 15, 2022 at 3:37 amzarakhai
SubscriberProblem with the output waveform
February 15, 2022 at 11:05 amNavya C
Ansys EmployeeHi @zarakhai Can you please share a screenshot from where are you plotting the waveform you mentioned?
Also share relevant screenshots of your model for better understanding.
Please use the image option and not the Attachment option while sharing the screenshots.
Regards Navya
February 16, 2022 at 2:26 amViewing 4 reply threads- The topic ‘Problem with the output waveform’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
