October 18, 2023 at 6:40 pm
javat33489
SubscriberHi all.
I am conducting a thermal analysis of drilling an SPG ram, using a model from LSTC. The mechanics work perfectly, everything is drilled, the voltages are normal. I want to enable thermal analysis.
I connect cards:
I'm using test parameters from my head (HC and TC).
And INITIAL_THERMAL with a temperature of 22С.
___
When calculating, I get the first entry in d3plot and look at it:
temperature on the drill is 85С
the temperature on the plate is simply horrid.
___
After the start of the calculation I received the following warnings:
Then I get an error and the calculation is completed:
Why?
Thank you.
October 23, 2023 at 5:57 pm
Ram Gopisetti
Ansys EmployeeHi,
what version of dyna are you using.
Any version 14 and higher should be good for SPG-Thermal studies.
Cheers, Ram
October 24, 2023 at 2:04 am
javat33489
SubscriberI'm using the version from the 2023 kit.
Tell me which cards should I show you? I would like to solve this error.
October 24, 2023 at 5:31 pm
javat33489
SubscriberHelp please
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3153
1680
1470
