Preprocessing
Preprocessing
Problem with two concentric tubes in Design Modeler
    • BrunoSilva
      Hello, I'm working on a axisymmetric problem of two concentric tubes with internal an external pressure.
      The issue comes trying to make b (external radius of internal tube) equal to b2 (internal radius of external tube). If I do that, the two surfaces become one.
      I'm currently considering b2 slightly greater than b and that is currently doing the work, but I want to know if there is a "cleaner" way to do this.
    • Keyur Kanade
      You can insert a new sketch on the same plane. Then this sketch will be different and you can create separate surface. nPlease see help manual for more details about these commands. nnRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help links
