Problem with UDF
    • andreaimpiombato
      I have a problem with the attached UDF.
      I need to create a parabolic inlet velocity profile varying in time. The problem is the profile that is generated is parabolic, but the velocity vectors are not directed perpendicularly to all as with x. I show an image for clarity.
      Thanks
    • DrAmine
      As ANSYS staff I do no ignore attachments. Run for more iterations and check the mesh at inlet.
    • andreaimpiombato
      The UDF is my inlet condition and must be a parabola that varies the intensity in time .... the calculation is transient.
      Best regards,
      Andrea
      What velocity boundary settings are you using?
    • andreaimpiombato
      I've used the velocity inlet condition.
      I've tried to use the old version of the software. In version 19.2 the UDF works fine.
      Thank you very much
      Andrea
    • DrAmine
      Probably post processing issue. Can you paste the lines of udf and velocity vectors of both runs.
Viewing 5 reply threads
