problem with wave reflection – transient analysis
    • Augusto13
      the structure in question is a fixed-free beam. I apply a pulse called Ricker (figure 1) of displacement at the fixed end of a beam. The expected path of the impulse is that a wave reflection occurs, but this does not happen in the  time history (figure 2).
      impulse Ricker:
                                                        Figure 1. Impulse
      Time history in the middle of the beam:
        Figure 2. Time history (ANSYS)
      I do not understand why the impulse disappears quickly.  I'm using the controlled damping (0,005) of ANSYS, I'm late, I got some help.
    • sk_cheah
      I'm guessing your beam is extremely stiff with the first natural frequency far exceeding the impulse frequency.
      Kind regards,
      Jason
    • Augusto13
      Hello, I think your analysis is correct.
      I changed the excitation frequency to 5 Hz (axial excitation), the natural frequency of the beam is 4.9 Hz (axial direction). So I got this:
        Figure 1. Time history
      but this seems to me unexpected. I would expect behavior similar to Figure 2 (ignore the captions and numbers):
                                           Figure 2. expected behavior.
    • sk_cheah
      Exciting the system very near the natural frequency with low damping will cause the system to ring at that frequency for a long time. Like a bell...
      You've now tried two cases. Try the last one: very high impulse frequency relative to natural frequencies.
      Kind regards,
      Jason
    • Augusto13
      organizing the tests (natural frequency of the beam is 4.9 Hz):
      1st test - excitation frequency of 79.36 Hz
      2nd test - excitation frequency of 5 Hz
      3rd test - excitation frequency of 0.666 Hz
      in test 3 I got this:
      when the excitation frequency is far from the natural frequency, the wave quickly dies. But when both frequencies are close, a sinusoidal behavior is observed. Would you have any other alternative? thank you!
    • peteroznewman
      Augusto,
      I recommend you plot
      relative tip displacement = tip displacement - base displacement
      which might show that test 3 is mostly rigid body motion.
      If I hold a ruler at one end and go up>down>up, the other end will follow and plotting relative tip displacement will show a flat line at zero.
    • sk_cheah
      For 4.9Hz beam, try excitation impulse of 500Hz. Be sure your simulation time step is about 5000Hz. Also, do a hand calculation on when you expect the wave to reflect back to make sure your simulation time is long enough to capture the reflection.
      Kind regards,
      Jason
    • Augusto13
      with 500 Hz ansys did not provide solution (I think the period was very small). I applied an excitation of 300 Hz (= 3,3e-3 s natural period), the behavior was identical to test 1 (see figure 1).  I always take care that the time step is much smaller (in this case 10x less).
        Figure 1. Time history (excitation of 300 Hz).
      In my calculations we have:
      1. time for wave to enter beam = 3,3e-3 s;
      2. time to pass in the middle of the beam = 0.028 s;
      3. time to reflect and return to the middle of the beam = 0.079 s;
      item 2 does not occur in the right time, there is something strange. In the time of 3,3e-3s the maximum peak of displacement occurs in every beam, as if the wave was so fast that all the points reach their peak at the same time.
      In item 3 the wave does not appear (stagnation of the graph to zero).
      the wave velocity is well calibrated. The beam has 16 m and I use a data input that give me a speed of 316 m/s.
    • Augusto13
      Peter, I think the result of ANSYS is already with relative displacement, when I add the time history in the fixed support, the result is always zero at all times. So I believe that at the tip (or at any point) the displacement is already relative, or I'm wrong ?
    • peteroznewman
      Augusto, yes, you are correct. I was thinking of another member's model that used a base displacement. Sorry for the mistake.
    • sk_cheah
      Augusto,
      I ran a simple model and plotted midspan displacement showing the reflection is quite close to the initial wave similar to your Fig 2 in your first post:
      Animation of the fixed-free beam: https://i.imgur.com/nFEjE4P.mp4
      Attached is v19.0 archived file of the model.
      Kind regards,
      Jason
    • Augusto13
      thanks for listening  =]
      I use ANSYS 17. I'm going to download from 19 and try to check where I'm going wrong. When I can, I'll post my mistake here.
    • Augusto13
      I finally got the final model. I only obtained the desired model when modeling without discretizing the thickness of the beam (model 2d). It seems to me that this experiment is only satisfied with this consideration, I still do not know the physical reason for this difference.
      thank Jason and Peter for the answers!
Viewing 12 reply threads
