Ansys Products
Ansys Products
Problem with workbench 18.1
    • Hassaan
      As I open workbench 18.1 (student version), I could not start any analysis as it does not appear in the toolbox. I checked all the analysis in the toolbox customization but no use. Any help in this regard would be appreciated. Thanking you in advance.
    • peteroznewman
      Uninstall ansys, and clean out two folders. In Windows Explorer, type %AppData% in the path field. You will be in the Roaming directory. Delete the Ansys folder, then go up a level and down to the Local directory and delete that Ansys folder too. Reboot the computer.
      Unless you need to use 18.1 for collaboration with other students, download ANSYS Student 18.2, unzip to a folder on your computer, then right click on setup.exe and Run as administrator.
    • Ayonz
      Hi there,  i have a challenge with ANSYS 18.2 student version. I installed the ANSYS AIM for student on my windows 8, upon running the workbench package,i noticed that the analysis component of the toolbox was not there, i reinstalled 3 times following the right procedure of running as administrator but all to no avail. i checkd online and there were suggestions that the package was not licensed, im not certain if thats the problem but i would appreciate if i can get a solution. i look forward to hearing from you preferrably through ayonz_1@yahoo.com...Many thanks. Ayonz
    • peteroznewman
      I answered this duplicate question in the new discussion you started. You can delete the post above.
Viewing 3 reply threads
