June 30, 2019 at 1:35 pm
wangwang
SubscriberIn workbench, I use Explicit Dynamics to create and mesh my model at first, and then, I import the model in Autodyn component system to analyze. When I click the 'Run' button in Autodyn, there are below errors warning and stop running.
1. Step Endtime in loadstep 1 must be unequal to zero
2. Step Endtime of step 1 is too small: 0.00000E+00
3. Endtime has been increased further than the last loadstep endtime (0.00000E+00). The settings of the last loadstep will remain
4. Step Endtimes should be strictly monotonically increasing
Is there anybody could fix it up? Thank you.
June 30, 2019 at 9:00 pm
SubscriberWhy do you export out and import into Autodyn?
Why don't you solve the model in Explicit Dynamics directly?
July 3, 2019 at 10:23 am
wangwang
SubscriberCause Autodyn can provide a easy way for me to do SPH method for my parts
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3930
2649
1865
1272
610
