Problems doing a Parametric Sweep with RMxprt and Maxwell
    • Zeke Ramirez
      I am new to Ansys and am designing a PM motor. I'm attempting to optimize rotor / stator variables using optimetrics. The issue I'm running into are my calculations / output variables. I want to see cogging torque (which isn't present in the list of variables) and maximum torque (which I can't get out of "shaftTorqueParameter" because it is plotted against angle).
      My end goal is to be able to test variables through a range of values to fine tune the motor's parameters. If someone has advice on how to do this (or a better way than what I'm doing), that would be great :)
    • Deyu Li
      If you create a Maxwell project from the RMxprt design, excitation could use variables which could be used to run optimiztion in optimetrics.
