August 30, 2018 at 9:17 am
vaibhav singh
SubscriberI m facing problem, when i solve the analysis, a message prompt "An unknown error is occurred during solution. Check the solver output on the solution information object for possible causes. Then further i checked my solution information, it shows GPU acceleration: NVIDIA library requested but not enabled. i do have 4 GB graphic card in my machine but not of NVIDIA. Does this software only support machine with NVIDIA graphic card. I do have many Softwares like Solidworks, Catia, AutoCad, Autodesk CFD ultimate, they works smoothly in my computer.
All i Want to know, Can i run this software on AMD Radeon ? please let me know ASAP
August 30, 2018 at 10:29 am
Ansys EmployeeWhat are you trying to run?
August 30, 2018 at 5:38 pm
- pcb
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- problems facing during solution
- Still facing the same issue
- Simulation of a single pillar of a peltier cooler
- Simulation of MoS2 with Au Nanoparticles
- Ansys Sherlock Mechanical Shock and Vibration Analysis Error
- Extraction of parameters of mosfet
- Simulation For Solar Module
- Apache Timing Engine error message
2524
2066
1279
1096
457
