Discovery Import
Discovery Import
Problems in running “battery clip plastic” in AIM structural simulation, can anyone help me?
    • dj.huang
      Hello:
      This is the file done by following the setup of example, "Structural Deformation of a Battery Clip Plastic". But however, I can't obtained the file whose results able to be successfully obtained. So, I attached the files and transcript error message here.
      I need help to know how to fix these problems......THX
      Original example Link: https://discoveryforum.ansys.com/t/k9dvtt
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Gaurav Sharma
      Hi Ding-Jun Huang
      I downloaded the battery clip example from forum. When I run this file, I didnt see any issue and the model converged easily, with 2019R2 AIM.
      Did you modify the setup of this example before running at your end. If yes, what changes you made?
      The error you are getting indicates the model is not properly constrained. As the model is working fine at my end, it seems some changes you added might be causing the problem with the model at your end.
      Thanks & Regards,
      Gaurav
      • dj.huang
        Gaurav_ANSYS
        At that time, I used AIM 2019 R1 to do and no convergence was obtained. But, today I have already obtained the convergence results by AIM 2019 R2.
        Maybe the error comes from the bug in contact interface definitions, and fixable in R2 because of some additional functions like formulation selection (Pure penalty is selected)...this is not found R1.
        Thank you for your comments very much!
        Sincerely
        Ding-Jun
      • Gaurav Sharma
        Ding-Jun Huang
        Good to see your problem is resolved.
        Gaurav
