Problems in SMART crack growth in DCB in 3D
    • Puhan
      Hello
      I hope you are doing well.
      I am trying to see crack propagation in dcb using SMART by making an arbitrary crack as following
    • David Weed
      Thank you for your question. Can you let me know where your local crack coordinate system is located?
    • Puhan
      Hello
      Thank you for the reply, here is the crack coordinate location you wanted.
    • David Weed
      I recreated a model with similar parameters and I am able to get crack growth using SMART:
      Can you check the ds.dat file for the crack tip node component information (right click on Solution and Open Solver Files Directory); mine has this:
      /com,*********** Done Sending CINT Commands For All Cracks ***********
      /com,*********** Send Crack Growth "SMART Crack Growth" ***********
      *set,cgid,1
      cgrow,new,1! Crack growth set
      cgrow,cid,1! cint id for crack growth
      cgrow,cfcm,NS_ARBCRACK_FRONT! Define crack tip node component
      Also, what are your settings for the Arbitrary crack object?
Viewing 3 reply threads
