problems in the interaction between solid to fluid domains in fluent
    • Alwan Hibatullah
      I'm doing a cooling simulation of an electric motor that uses a water cooling system. but it seems there is a problem between solid to fluid domain interactions. where when heat flux is applied to the solid domain and propagates to the fluid domain, the results are invalid. but when my inter-domain connection is broken and heat flux is applied to the fluid domain, the result becomes valid
      Does anyone know how to maximize heat transfer between solid and fluid domains so that the Nusselt number results are valid?
    • SRP
      Hi, I suggest you please check cource on conjugate heat transfer: Simulation Setup for CHT analysis | Ansys Courses
      Hope this helps you.
      Thank you.
    • Alwan Hibatullah
      hello,
      thanks for the reply
      but I used ansys fluent for this problem solver and not discovery, and I didn't understand when I saw a tutorial using ansys recovery because it's the first time I saw it. is there another video that is more specific to ansys fluent?
      Thank You
    • SRP
      Here is the course in fluent related to conjugate heat transfer: Tutorial – Heat Transfer Modeling in Ansys Fluent | Ansys Courses
      Thank you.
    • Alwan Hibatullah
      I've made sure that my fluent setup is correct, the solid to fluid domains are connected as coupled. but the results are still wrong, for example the heat transfer analysis on Re 500 should get a Nusselt number of 12, but what I get is only 5. is the problem with the meshing such as the inflation layer or some other part? considering that even I have used y+ = 1 but the result is still not valid
Viewing 4 reply threads
