Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Problems in the meshing of my geometry
    • André Henrique
      I am not able to generate the mesh of my project, the mesh simply fails or gives the following problem. "the meshing has completed, but some elements are not compliant with the applied shape checking criteria ansys".
      The solutions I tried didn't work. I'm still learning about Meshing, so I don't have much knowledge to troubleshoot the problem.
      The Geometry is as follows, it consists of several tubes varying in size around a larger cylinder as shown in the attached image.
      Still, there is an Enclosure that covers geometry,
      From what I understand, the part that is giving error is the Enclousure Meshing process.
      Is the tube the same size (z direction) as the box? How far apart are the annular sections, and did you split them out? Which solver are you going to be using?
    • André Henrique
      The box is larger than the tube in the z direction, it is 200mm larger
    • André Henrique
      And yes, they are different components
      OK.  If they're different components, how large are the cells relative to the gaps? If the surface facet is large compared to the gap you'll get some very skew cells.
    • André Henrique
      The larger cylinder has a radius of 400mm and the smaller ones vary in radius from 1.96mm to 6.81mm and their centers are 16.76mm apart.
      As in the following image:
    • André Henrique
      I disabled the Check Mesh Quality option and managed to generate the mesh (otherwise it would not be possible to generate it due to the errors described above), but the mesh appears to be of poor quality. I'm just using body sizing and MultiZone. Please, check right below what I have got.
      *As you can see in the image below, there is also a larger solid surrounding the others in this case (it's a PML).
      That mesh is pretty impressive. I've not seen the Meshing tool achieve something that messed up and not crash before!
      Assuming the smaller tubes don't touch, you need a cell size that's smaller than that gap otherwise nothing can flow between the tubes. Read up on proximity and curvature size functions. Read up on hard and soft sizing, and then using the above work out why hard should be used with extreme caution.
      There's a physics option in Meshing too. That sets defaults for smoothing etc. Make sure you've got the correct physics and solver selected.
    • André Henrique
      Okay, I will read then.
      Thanks.
Viewing 8 reply threads
