Ansys Products
Ansys Products
Problems launching ANSYS from the Mechanical APDL Launcer
    • ryan11112
      Hi, I just install Ansys 2020 R1 but when I try to open Mechanical APDL it says can't find mkl_intel_thread.dll, how can I fix it?
    • tsiriaks
      On the launcher page, go to High Performance Computing Setup tab -> Check the radio button for Shared-Memory Parallel (SMP) and define the number of processors to be 1
      Do you still see the same error ?
    • ryan11112
      Yes, still see the same error.
    • ryan11112
      sir what should I do now?
    • tsiriaks
      post the output of
      set
      command from CMD Prompt
      Also, output of this command
      dir /s "C:*mkl_intel_thread.dll*"
    • ryan11112
      I post those command but still the same error sir.
    • tsiriaks
      Please post the outputs of the two commands here (in this forum)
Viewing 6 reply threads
