October 30, 2018 at 9:11 am
jmt714
SubscriberHi
I'm a student, using for first time Fluent and I am using the following UDF. My Ansys version is 18th. But when I try to compile it I get this error: The UDF library you are trying to load ( libudf) is not compiled for parallel use on the current platform (win64).nnThe system cannot find the file specified.C:UsersUserDesktopProva_3 libudfwin643d_hostlibudf.dll.
I don't know if is because the lack of any compiler or because the udf is wrong.
Any suggestions? Thank you very much in advance and sorry for the inconveniences,
October 30, 2018 at 9:16 am
jmt714
My UDF is the following: I am trying to do a simple movement of a plane in one axis. Thus, all the nodes of the surface would move equally (either up or down). I have already the displacements and it's a 106 steps simulation. That's why I define a vector (106 positions), each position of the vector is the displacement of the surface at that step.
#include "udf.h"
#include "dynamesh_tools.h"
int last_ts = -1;
DEFINE_GRID_MOTION(mitral,domain,dt,time, dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(axis);
int n;
real displ[106]= {0, -0.0000912592592592591, ... until reach 106 values};
NV_D(axis, =, 1.0, 0.0, 0.0);
int curr_ts;
curr_ts = N_TIME;
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
if (NODE_POS_NEED_UPDATE (v) && last_ts != curr_ts)
last_ts = curr_ts;
NODE_POS_UPDATED(v);
NV_V_VS(NODE_COORD(v),=, axis,*,displ[last_ts]);
end_f_loop(f,tf);}
October 30, 2018 at 9:32 am
seeta gunti
Ansys EmployeeHi,
The error is because of lack of compiler. For compilation and loading the UDF, please check the below link which gives complete idea on installation of Visual Studio and compilation of UDF using VS command editor.
Seeta
October 30, 2018 at 11:25 am
jmt714
SubscriberMany thaanks!!!
2656
2120
1345
1118
461
