Problems reaching convergence
    • simonhenn
      I am simulating an airflow over a flate plate. While I have solved earlier problems where I often got a floating point exception the solution still doesn't really converge. These are the oscillating residuals:
      The residuals suggest some transients in the flow. The pressure plot implies it's not converged, so have a look at images of pressure, velocity etc to see what's still changing: possibly a separation zone is moving around which may mean there's a low pressure region that's not very stable. nHow does the mesh look when you plot the flow results onto it? Have good cells doesn't necessarily mean you have a good mesh. n
    • simonhenn
      Thanks for your answer! What exactly do you mean by plotting the flow results onto the mesh?
      Plot contours with the mesh on that isosurface/plane on and node values off. It lets us see the cell data and we can judge if the mesh is resolving the flow gradients. n
    • simonhenn
      Here are some pictures of the complete Mesh and possibly critical regions. Let me know if you need some more info. n
      Top contour shows some of the issue: you've got a fairly big jump in cell size and a very stretched cell right where the flow separation is trying to happen. It's also a fairly complex shape for the flow so could take a lot of iterations to sort itself out if the mass flow splits become part of the solution. n
    • simonhenn
      Ok, so I'm gonna make the transition between the cell sizes smoother. Then are the high aspect ratio boundary layer cells no problem anymore?n
      You need to be wary if the solution is changing down the length of those cells. Inflation layers are very good for attached flow to give you a cheap mesh with low y+ however they're not good if you have flow separation or jet impingement. n
Viewing 7 reply threads
