Discovery Import
Discovery Import
Problems with 1st install and start up of Discovery Live.
    • nfgriffiths
      Just installed discovery live. When opening Discovery Live, the UI displayed does not match the UI shown on the tutorial videos. Most notably, the on screen icons and the 8 block window which is supposed to display when a new session is started does not display. It almost feels like the software is just running Spaceclaim but the window header is stating that Discovery Live is running a session. I can model parts using the modelling tools but cannot find the menus to start to drive any type of real time simulation. Of the two images, the one I see when I open Discovery live is the one with no on screen icons. Does anyone have any clues or tips around what the issues here might be?
    • Brian Bueno
      Neale It's difficult to say without more information. Does your hardware meet the minimum requirements for running Discovery Live? https://discoveryforum.ansys.com/t/801xrx/ansys-discovery-hardware-requirements That is a common cause for odd problems like this one.
    • nfgriffiths
      Thanks for your reply BBueno_ANSYS
      I have run the hardware check files and the Nvidia graphics card and hardware all seems to check out OK. The software opens OK and I can model 3D parts it's just that I cannot see any of the features for running FEA etc... It's almost like Discovery Live has opened but it is only running the Spaceclaim side of the package.
    • philipvdm
      Hi Neale , i had the same problem. the graphics driver does not load. are you connecting with a remote desktop? i must connect my screen with a HDMI cable.
    • Brian Bueno
      Neale
      You should also make sure that your graphics drivers are up to date. Go directly to NVIDIA.com and check for the latest drivers for your card there.
    • akhaskia
      I have the same issue. Graphics and hardware requirement are all met.
    • nfgriffiths
      We have fixed our issue. I think some of it was our own doing. We installed Discovery Live as part of ANSYS 19. Discovery live would not run properly. We have now re-installed the Discovery Live elements separately and the software is now running OK.
Viewing 6 reply threads
