Problems with ANSYS Mechanical APDL… MESH and geometry export?
    • mohammedlaminemekhalfia
      Dear.
      I have this Blade in APDL, and I am not much proficient user in that.
      I used to work on workbench, In this topic I am willing to compare between different blade geometry where I had mine and several others. below is a Blade obtained from a constructor performed in APDL
    • Akshay Maniyar
      Have you tried Archive model option from preprocessor? or just exported using File regards amaniyar
      I directly use the File< export.
      I will try again with archive thank you
