Problems with esel
    • John Miller
      Hello together,
      I’m struggling a little bit with the element selection of in /prep7-created thermal surface elements.
      The model is really simple a cube with convection load at the surfaces, except the top surface.
      Model:
      Cube 10 mm x 10 mm x 10 mm
      208 nodes
      40 nodes on the top surface
      27 elements
      148 nodes at the exterior surface, except the top surface (I know the corner nodes)
      And 9 elements contain the nodes of the top surface
      The code for the creation of surf152 elements looks like:
      /prep7
      /GOPR
      /com,*********************Start surf152*********************
         nsel,none
         esel,none
         esel,s,ename,,surf152         ! Element selection of surf152 elements
         nsel,stat
         esel,stat
         cm,ELsurf152,elements         ! Create a component which includes surf152 elements
         nsel,stat
         esel,stat
         edele,ELsurf152               ! Deletion of former surf152 elements
         nsel,stat
         esel,stat
         et,100,152,,,,,0              ! KEYOPT(5) = 0, No extra nodes.
         cmsel,s,external,node         ! Select nodes for esurf
         nsel,stat
         esel,stat
         esln,s,0                      ! Select the elements of the selected nodes
         nsel,stat
         esel,stat
         type,100                      ! Asign element type 100
         esurf                         ! Surface Elements generation
         nsel,stat
         esel,stat
         allsel,all
      /com,*********************Ende surf152*********************
      /solu
      And the corresponding solver output is:
                ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
       NONE SELECT  FOR ITEM=NODE COMPONENT=
        IN RANGE         1 TO        208 STEP          1
                0  NODES (OF        208  DEFINED) SELECTED BY NSEL  COMMAND.
       NONE SELECT  FOR ITEM=ELEM COMPONENT=
        IN RANGE         1 TO        126 STEP          1
                0  ELEMENTS (OF         72  DEFINED) SELECTED BY ESEL  COMMAND.
       SELECT       FOR ITEM=ENAM COMPONENT=
        IN RANGE       152 TO        152 STEP          1
               45  ELEMENTS (OF         72  DEFINED) SELECTED BY  ESEL  COMMAND.
       ****** STATUS OF NODES ******
       NUMBER OF SELECTED NODES=         0
       NUMBER OF DEFINED NODES=        208
       MAXIMUM NODE NUMBER=            208
       ****** STATUS OF ELEMENTS ******
       NUMBER OF SELECTED ELEMENTS=        45
       NUMBER OF DEFINED ELEMENTS=         72
       MAXIMUM ELEMENT NUMBER=            126
       DEFINITION OF COMPONENT = ELSURF152  ENTITY=ELEM
       *** WARNING ***                         CP =       0.547   TIME= 11:00:35
       Assembly ELSURF152 is deleted.
       NUMBER OF SELECTED ELEMENTS=         0
       NUMBER OF DEFINED ELEMENTS=         27
       ELEMENT TYPE        100 IS SURF152      3-D THERMAL SURFACE
        KEYOPT( 1- 6)=        0      0      0        0      0      0
        KEYOPT( 7-12)=        0      0      0        0      0      0
        KEYOPT(13-18)=        0      0      0        0      0      0
       CURRENT NODAL DOF SET IS  TEMP
        THREE-DIMENSIONAL MODEL
       SELECT      COMPONENT EXTERNAL
       NUMBER OF SELECTED NODES=        16
       SELECT      ALL ELEMENTS HAVING ANY NODE IN NODAL SET.
                9 ELEMENTS (OF         27  DEFINED) SELECTED FROM
             16 SELECTED NODES BY  ESLN COMMAND.
       NUMBER OF SELECTED ELEMENTS=         9
       ELEMENT TYPE SET TO       100
       GENERATE ELEMENTS ON SURFACE DEFINED BY SELECTED NODES
        TYPE=      100  REAL=        1  MATERIAL=        1  ESYS=    0
       NUMBER OF ELEMENTS GENERATED=          1
       NUMBER OF SELECTED ELEMENTS=        10
       NUMBER OF DEFINED ELEMENTS=         28
       MAXIMUM ELEMENT NUMBER=            127
       SELECT ALL ENTITIES OF TYPE= ALL  AND BELOW
      Why are 45 elements selected via esel ?
      There shouldn'be any surf152 elements because it's the first step!
      The output indicated that one surface element is created, I guess at the centre of the top surface. Because all external nodes of the element surface are necessary to create a surf152 element at the exterior element surface.
      After re-entering the /solu I try to select the in /prep7 created surf152 elements with this code:
        nsel,none
        esel,none
        esel,s,type,,100
        esel,s,ename,,152
        esel,s,mat,,100
        cm,surf_test,elem
        allsel,all
        outres,all,all
      *enddo
      The solver output is this:
       *** WARNING ***                         CP =       0.797   TIME= 11:00:37
       Entity 100 is undefined.  The ESEL command is ignored.
       SELECT       FOR ITEM=MAT  COMPONENT=
        IN RANGE       100 TO        100 STEP          1
       DEFINITION OF COMPONENT = SURF_TEST  ENTITY=ELEM
       WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
         FOR ALL APPLICABLE ENTITIES
       *ENDDO  INDEX= I
      I don’t understand this, because one surf152 element is created in the /prep7, but in the /solu I can’t select it via esel.
      I also don't understand why 45 surf152 are selected prior in the /prep7 in the first step, there shouldn't be any of these
      With best regards
      John
    • Daniel Shaw
      It is difficult to debug MAPDL scripting in Mechanical without the model and full access to the script?  For example, it is not clear why you believe that there are no SURF154 in the 1st load step. Did you create the surf elements in 2nd load step?  I recommend that you open a Service Request through the Customer Portal, so that you can provide the model to us.
