September 5, 2022 at 8:37 am
atiwari
SubscriberHello everyone,
I am trying to solve the FSI problem in workbench (transient + fluent) based on the ANSYS How to Tutorial on ANSYS Workbench 2021R1. The link to the tutorial is attached below.
I have managed to solve the full fsi problem without any errors but i am facing problems in the post-processing part as shown in figure below
As told in tutorial it is said to connect solution of transient structural .i.e. B6 to results of fluent i.e. C6. But when i try to connect the workbench is not connecting it showing the denied
sign. Can i anyone help me figure out the way or tell me what i am doing wrong with this setup.
Thanks in Advance.
Abhinav
September 6, 2022 at 5:27 am
Nikhil Narale
Ansys EmployeeHello Abhinav,
Just a thought. Can you drag a standalone 'Results' component system into the project schematic and try connecting solutions of both the Transient structural and Fluent to the results?
September 6, 2022 at 5:38 am
atiwari
Subscriber-
September 8, 2022 at 12:05 pm
RM
You can view the coupled analysis results in Ensight.
To view coupled results in EnSight you you have to follow the procedure as. (https://forum.ansys.com/uploads/149/HUBQN99F4L5X.pdf)
- Load System Coupling results. For the Look in field, navigate to System Coupling's results folder, \dp0\SC\SC\SyC\Results
- Load Mechanical results.
> File > Open > Enable keep Currently Loaded data > (load .rst file from \dp0\FFF\MECH) Enable advanced interface > Load all parts
3. Load Fluent Results
> File > Open > Enable keep Currently Loaded data > (load .rst file from \dp0\FFF\Fluent) Enable advanced interface > Select .cas file
Edit both file names, replacing the step number with a wild card, as follows:
\dp0\FFF\Fluent\FFF.1-1-*.cas.h5
\dp0\FFF\Fluent\FFF.1-1-*.dat.h5 and load all parts.Hope that helps!!
Rahul
September 21, 2022 at 3:02 pm
Stephen Orlando
Ansys EmployeeLoading Mechanical results in CFD-Post is no longer supported as of 2021R1. This is mentioned here: 3.3. Incompatibilities (ansys.com)
2646
2110
1337
1112
461
