December 14, 2017 at 11:38 pm
Mr_fixit16
SubscriberHello everyone,
I am looking for some help generating a good mesh and was wondering if anyone has any ideas.
Attached are screenshots of the best hex-dominant mesh i have been able to generate and the associated settings. The problem is the highly skewed elements between the fine inner mesh and the coarse outer mesh. I prefer to avoid tetrahedrons due to the large number of elements generated, however i do get a good mesh with tetrahedrons (based on skewness).
It seems to me, the mesher should generate successively smaller hexahedrons to step down to the smaller elements, but instead it generates apparently random tetrahedrons and such.
Any tips or advice here would be greatly appreciated. Thanks!
December 15, 2017 at 6:58 am
Jimmyhan
SubscriberI need to see total structure in order to find where the problem comes from. By the way, I dont think hex dominant meshing is a good selection for boundary simulation.
December 16, 2017 at 9:44 am
Raef.Kobeissi
SubscriberWhy don’t use the Cut Cell mesh method and the manual sizing function? -
May 29, 2019 at 5:13 pm
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2600
2082
1317
1108
459
