May 25, 2023 at 5:19 am
Leonid Pascar
SubscriberHi,
I try using to optimize an array of etched slots and I followed the example of inverse design of grating coupler. I defined the params using FunctionDefinedPolygon or ParameterizedGeometry. In both cases, the inital shape is correct, but the optimization end before the first iteration saying that projg=0. Which is incorrect as the FOM is far from the target. I understand that gradients are not really calculated. Could you please advise about why it happens?
I pasted below the output of the optimization
Thanks,
Leonid
At iterate 0 f= -2.40344D-01 |proj g|= 0.00000D+00
Tit = total number of iterations
Tnf = total number of function evaluations
Tnint = total number of segments explored during Cauchy searches
Skip = number of BFGS updates skipped
Nact = number of active bounds at final generalized Cauchy point
Projg = norm of the final projected gradient
F = final function value* * *
N Tit Tnf Tnint Skip Nact Projg F
17 0 1 0 0 0 0.000D+00 -2.403D-01
F = -0.24034417377896422 -
May 25, 2023 at 7:04 pm
Guilin Sun
Ansys EmployeeMy colleague is busy in projects. I just want to suggest to check the optimized parameter and see how does it modify the polygon. You may try a sweep and see if the parameter can actually apply to the polygon.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5414
3389
2471
1310
1022
