Problems with Nodal label
    • Oymegi
      I have the following problem in mechanical APDL :
      I’m making an axisymmetric model with PLANE25 (imposed ETYPE) and I’m applying force loads at nodes with a FX, FY, MY and MZ labels (F,cm,FX,Value).
      But when it comes to apply MY and MZ load Ansys show the following warning :
      *** WARNING ***                        CP =     14.844  TIME= 17:32:34
       The NODAL LOAD label of MY is not part of the currently active set.
       The current NODAL LOAD set is: FX FY FZ .
      Does this problem come from Plane25 elements ? (As I understood PLANE25 elements allow non axisymmetric loading )
      Thanks
    • Erik Kostson
      Hi
      See the help manual (plane25) for more information.
      In general though axisymmetric FEA has X and Y degrees of freedom (plane25 has that also) -> FX and FY should be possible nodal loads as the warning indicates ('The current NODAL LOAD set is: FX FY FZ').
      So we do not have rotational degrees of freedom in axisymmetric elements -> hence moments (MY,etc) can not be applied to them (as the warning says: The NODAL LOAD label of MY is not part of the currently active set.).
      All the best
      Erik
