Problems with selecting bodies
    • ciema
      Hello, need solution for the problem: I built a big model in SpaceClaim and shared topology. At the specific stage of building I couldnt select bodies. I know how to fix it (solution is to cut and paste all bodies), but this method will destroy my whole share topology in method.nHas anyone had this kind of problem and found solution without deleting share topology?n
    • ValiullinDamir
      Hi, Array! nWhat do you mean, when you say Share topology? Do you use this button:nAnd if it is possible, can you attach some pictures of your model and this problem?n
    • ciema
      Thank you for reply. I cannot attach pictures unfortunately. But its very simple. I used share topology in workbench tab in SpaceClaim. And i m not able to select bodies with box selecting mode no matter what filter of selecting in SpaceClaim i use. All i can do is select a single body, but its not so practical, because my model is big... My version is 2020 R1. n
