Problems with self-intersection in Fluent Meshing
    • marco_ntnu
      Hello!
      I want to mesh a cubic lattice structure as a solid to do some thermal simulations in Fluent. For this I have imported a stl file to Spaceclaim as a faceted body. While checking the faceted body for errors, I do not get any, especially no self-intersection one.
      However, when I want to mesh it in Fluent Meshing, the surface mesh will fail as it has self-intersections all of a sudden.
      is there a fix for this? Or is there already a problem with the stl file?
      The goal would be to have a mesh with around 2 Million elements with a tetrahedral mesh.
      Thank you very much already in advance!
      PS: I have attached the workbench archive of this project as a split .rar file
      Staff are not permitted to open or download attachments. Can you check the surfaces in SC and see if there are any very small gaps?
    • marco_ntnu
      Hey I checked the surfaces and no gaps were detected. However, in the end I managed to mesh it. It seems that a too big minimum size for the surface mesh caused self-intersecting mesh elements. After I set it to a low enough value, the mesh could be computed successfully.
      Excellent. You'll have been bridging between surfaces so effectively created holes in the domain.
Viewing 3 reply threads
