problems with single reference frame with only translation
    • gao.1571
      I am testing a welding case with the single reference frame approach.
      The tutorial says a transient problem becomes a steady state problem with the moving reference frame. This is like the welding case where the temperature field reaches a steady state when you travel with the heat source. In welding, the steady temperature field has a ellipse shape because of the welding speed, e.g.,
      In my model, the cell zone uses frame motion - single reference frame with X velocity v = 0.1 m/s, top surface has a heat source q = f(x,y) and all the surfaces are stationary. Besides, only the energy equation is activated.
      The temperature field i get is a circle. It seems like the moving reference frame doesn't work.
      Appreciate any help.
    • Prashanth
      You mentioned you are using a spatial energy source. Source gets applied over a collection of cells. I believe those cells happen to be within the single zone you that have and moves along.
    • gao.1571
      Yes. My heat soure (surface flux) is applied to the top wall with origin being x = 30mm, y = 0 and heat source radius = 3 mm. I want the moving reference frame is attached to the heat source.
      Does my case fit the single reference frame approach?
    • Prashanth
      I don't think SRF approach can be used. Unless you want to turn it into a transient Fluent problem and implement solidification/melting models, transient thermal in mechanical can be used instead.
      • gao.1571
        So can you give a reason why it does not work? It does not violate the principle of SRF.
Viewing 3 reply threads
