May 17, 2018 at 1:40 pm
saraahf1
SubscriberHi, I have some problems with the contact generated between more than 2 beam elements.
I've created about 200 beam elements by lines. and they are located in columns and rows. In order to create the contact between one beam and its neighbouring beams I've created a contact between all this beams saying that the first beam from the first row is the "Conta176" of the second beam from the first row that is its "Targe170" but at the same time it's the "Conta176" of the third beam from the first row that is its "Targe170" and so on.
The program gives me some warnings which I don't know how to solve. The warnings are the following (the first two are repeated more than once:
- The normal of target element 7502 is not consistent with the normal of target element 7517 in real set 1. Please use the ENORM command to correct it.
- The normal of contact element 8587 is not consistent with the normal of contact element 10077 in real set 1. Please use the ENORM command to correct it.
- The self contact pair specified by real constant set 1 also overlaps with another symmetric contact pair (e.g. 1).
Does anyone know how to solve the problem keeping the contact between all the beams as I've specified at the beginning?
Sarah.
May 17, 2018 at 7:24 pm
May 18, 2018 at 7:42 am
saraahf1
SubscriberThank you for your answer! I'm modeling the model in ANSYS APDL using the Macro code. In my case the beams have an external parallel contact as you can see in the picture (C=conta176, T=targe170). My code is the following:
!1st row
*do,i,5,10
*do,j,1,1
xpos=(i-0.5)*pitch !Change position
ypos=(j-0.5)*pitch
lsel,s,loc,x,xpos,xpos !select lines x plane
lsel,r,loc,y,ypos,ypos !select lines y plane
lsel,r,loc,z,zbsuk,zbsok !select lines z plane
nsll !select nodes from the selected lines
esll !select elements from the selected lines
type,3
esurf !generate elements on existing selected elements
xpos=(i+0.5)*pitch !Change position
ypos=(j-0.5)*pitch
type,4
*enddo
*enddo
I guess that what the program means with the third warning that I specified in the previous post is that I can't say that one beam is the contact element and target element at the same time. However I have no idea how to solve it and also the first two warnings.
May 18, 2018 at 4:52 pm
SubscriberHi Sarah,
I don't understand what you are showing in the image above.
I don't know what you mean by "external parallel contact". Do you mean there is a grid of parallel beams?
May 24, 2018 at 3:54 pm
saraahf1
SubscriberYes there is a grid of parallel beams
May 26, 2018 at 10:54 am
SubscriberI recommend you assign each beam to be black (Target) or white (Contact) like a checkerboard. That way each beam will have contact with its four adjacent neighbors that each touch a face.
This will not define any contact between the other four neighbors that the beam initially touches only an edge.
You have 200 beams so maybe you can do the assignment manually. However, I looked up the pseudo code for creating a checkerboard pattern and it goes like this:
The key to the code is to compare modulo2(i+j) with 0 and if true, that defines black.
May 26, 2018 at 11:34 am
saraahf1
SubscriberThank you for the suggestion! I'll try to do it in this way.
September 11, 2018 at 2:59 pm
Subscriber@aliBaratian,
I moved your post to a new topic since this topic is already marked as solved.
October 11, 2018 at 12:51 pm
Likth
SubscriberHi saraah,
You tell here that it is not possible to make the same beam element as both target and contact elements at the same time. Well, i had such a problem while modeling technical textiles and it is possible to make the same beam element as both contact and target surface at the same time but the trick is to give it a different contact ID. This way, it is possible to establish contact between 1st row of beam elements(contact surface) and 2nd row of beam elements(target surface) and then contact between 2nd row of beam elements(contact surface) and 3rd row of beam elements(target surface). As you can see, second row of beam elements are both contact as well as target surfaces. Hope this helps!!
Likith
3137
2377
1306
922
