Procedure to use DDES Turbulence model
    • Sakun
      As a part of my research project i need to simulate my high-speed single compressor blade simulation in DDES turbulance model. I do have a converged solution (attached picture) using steady-state RANS 2nd Order scheme and i would like to know, do i have to follow the same procedure as LES model as mentioned in the fluent user manual for the DDES as well.
      Thank you,
    • Federico Alzamora Previtali
      you should follow the DES procedure as per the manual 13.12. Setting Up the Detached Eddy Simulation Model (ansys.com)
      • Sakun
        Thank you very much for the reply,
        But according to the user manual there is a section how to initialize LES based simulations (13.19.5. LES-Specific Solution Strategies). So i am just wondering DDES based simulations also have to initialize like LES.
          For DDES, a standard steady-state RANS should be sufficient.
        • Sakun
          sorry i didnt get what you meant by "standard steady-state RANS for DDES"  ☹
