April 1, 2022 at 3:16 pm
vlehmann
SubscriberHi All,
I am trying to run an single frequency HFSS simulation on an HPC and get the error "process hf3d exited with code 149". Does anyone know what the error means or where I can find out how to fix it? I was able to run this simulation on a local server without issue.
Thank you,
Valerie
April 12, 2022 at 11:29 amPraneeth
We need more information on this to serve you better.
There can be multiple reasons for this error.
Please check below points and take action accordingly.
At what stage of simulation this error is triggered - like adaptive meshing stage, frequency sweep?
Are you running manual HPC setup or the automatic? If you are using manual then try automatic once.
Does your HPC machine has enough RAM?
All the very best Praneeth.
April 12, 2022 at 6:24 pmvlehmann
SubscriberHello Praneeth The error is triggered right after "Adaptive Pass #1 - Solving single frequency for adaptive meshing". The full error says that "Design:HFSSDesign1 (DrivenModal), Solving adaptive frequency ... (Domain solver), process hf3d exited with code 149."
The HPC is automatic I believe. How would I be able to tell if I have enough RAM? I didn't see an error about the RAM.
Thank you Valerie
January 17, 2023 at 9:59 pmparhamz
SubscriberHello all,
How did you solve this problem ? I have Ansys electronics desktop 2022 R2 working on ubuntu 20.04 . I made my mesh pretty coarse and I have a lot of RAM and CPU power on my local machine and I still get this error. No matter I use direct solver or iterative solver I get the same issue. What is the solution for this problem ?Here is the detail of the error that I get:
C_to_Sq_transition (/mnt/DD/ansys_electronics_projects/project_test/)
Transition_wr75 (Modal Network)
[error] Solving frequencies ... (Nondomain solver), process hf3d exited with code 149. (1:55:20 PM Jan 17, 2023)
[info] A discrete frequency sweep with 17 point(s) has been started using HFSS - Solving Distributed. (1:55:42 PM Jan 17, 2023)
[info] Discrete frequency sweep complete. (1:55:42 PM Jan 17, 2023)
[error] Sweep first_analysis_sweep_coarse failed (1:55:42 PM Jan 17, 2023)
[error] Simulation completed with execution error on server: Local Machine. (1:55:42 PM Jan 17, 2023)Viewing 3 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1327
1110
461
