March 7, 2021 at 9:51 pm
MatiasB26
SubscriberNo, size (volume) of the patch region.March 8, 2021 at 3:32 amKeyur Kanade
Ansys EmployeeThe error may be suggesting that you do not have sufficient memory for adaption. After adaption the cell count is increasing so that your machine is not able to handle. nThe original discussion was for patching the region. This discussion looks like for adaption. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 8, 2021 at 3:57 amMatiasB26
SubscriberHow can I know what is the limiting factor of my machine? This could allow me to look for a machine where I could run my simulation. I know is not the RAM because I was monitoring the memory performance as I was trying to run the simulation. Also, the original discussion still without an answer. if you could respond to it as well I will highly appreciate it.nMarch 8, 2021 at 3:57 amMatiasB26
SubscribernMarch 8, 2021 at 4:40 amKeyur Kanade
Ansys EmployeeFor Fluent, you can take 1 to 3GB per million cells to read. Further it depends on models you are using. nViewing 4 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
459
