September 19, 2023 at 3:12 pm
Imre Biro
SubscriberHi There,
The HFSS 3D Layout help has a single page about adding a programmatic EDC cell. Is there any other documentation, or at least a single working example on how to use it? The provided interface is not particularly straightforward.
If I'm not mistaken it is calling .NET functions through IronPython, thus there is zero type information or any other pointer to make it work.
I'm on 2022R2.
Thanks,
Imre -
September 20, 2023 at 2:36 pm
Aymen
Ansys EmployeeA very convinent way is to use PyAEDT
https://aedt.docs.pyansys.com/version/stable/EDBAPI/index.html-
September 20, 2023 at 10:43 pm
Imre Biro
SubscriberHi Aymen, thanks for the reply.
I am aware of PyAEDT. My goal with the scripted component would be to have it insered in a design and, if my understanding is correct, update based on the code on parameter changes. E.g. create variable amount of primities.With PyAEDT (or the built-in regular scripting interface) I manually have to run the script to make those updates.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2963
1449
1322
