November 11, 2017 at 1:17 pm
SubscriberAn edX Student asks: Can anybody suggest how to calculate failure load in the progressive damage analysis using ANSYS ACP module or in ANSYS Workbench? I am able to see the progressive damage status, maximum failure criteria etc. But how to find the comparable failure load which we see in the actual testing of the joint on Universal Testing Machine, i.e., Maximum tensile load or failure load. I am working on bolted joints in woven fabric reinforced composite materials.
July 2, 2019 at 9:13 am
viv123
SubscriberHello peteroznewman,
What is the way to simulate woven fabric (yarn) model with the user-defined material model(equations obtained from the theory or experiments) and properties in Ansys?
Thank you in Advance
July 2, 2019 at 11:28 am
SubscriberI have never used it, but I see there is a category at the bottom called Custom Material Models in Engineering Data and a button to Create Custom Model.
July 4, 2019 at 6:00 am
viv123
SubscriberOk, sir,
Can we add stress-strain relationship in a equations form with strain rate dependency of the material model?
Thank you
July 4, 2019 at 9:21 am
SubscriberThere are material models that have a strain rate dependency. Look under the Viscoelastic category.
July 5, 2019 at 4:21 am
viv123
SubscriberOk sir, Thank you can we write our own material model.
2098
1321
1108
461
