Discovery Import
Discovery Import
Project onto the grid
    • rg
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello I think there is an error in the project to grid command by selecting create layout curves. The surface is created that in theory should not be created by activating create layout curve   Best Regards
    • Charudatta Bandgar
      Hello Roberto , It did work for me as intended, let me see what could be wrong. (Let me know if I understood it right.) Since we have seen issues with Italian as a language, can you switch to English and see? I am not sure if that will work, but that will clear that possibility. Regards.
    • rg
      Charudatta Bandgar Hello
      Correct you are right , setting the language in Italian does not work
      Best Regards
      Hello Roberto , I found out the possible thing here. I think it works with constraint-based sketching, but not with the older sketching mode. I disabled constraint-based sketching, and it showed me a similar issue (as you). I will file a bug for this, I think for time being as a workaround, you can use constraint-based sketch mode while using the operation, while I investigate this more.
      Hello Roberto ,
      Please try with constrained based sketch mode. Let me know, if that works for you.
      Regards.
    • rg
      thank you veryy much , perfect
        Hello Roberto ,
        I have filed a bug (Bug ID: 368111) why it is not working in the older mode (with constraint-based sketching disabled), I will let you know if I know anything.
        Regards.
Viewing 5 reply threads
