October 22, 2018 at 9:55 pm
mahmoud
SubscriberHi,
I am having a trouble drawing an FSS on a reflector antenna in order to design a radome. So far I have:
1- A planar 2D FSS pec
2- A reflector made by rotating an equation based curve (I can also thicken it so it can act as the substrate for the FSS)
I am having trouble in the final step where i want to project or wrap FSS on the inner part of the reflector. I tried Modeler >> sheet>wrap but it gives an error.
Any help is appreciated
October 22, 2018 at 10:10 pm
asamaiyar
SubscriberHi mahmoud,
Sheet > Wrap only wraps around a solid body. Give your reflector some volume. Maybe give it finite thickness and that should work.
AS
October 23, 2018 at 12:29 am
mahmoud
SubscriberThank you Asamaiyar. I tried wrap but it did not work. Actually Project surface worked (but i have to vary the thickness+number of segments sometimes it gives weird results)
http://www.edatop.com/hfss/35310.html
- Maxwell, HFSS or Q3D?
- Error
2522
2064
1279
1094
456
