Discovery Import
Discovery Import
Projecting lines on a surface
    • tandama
      How do I project lines on a surface and keep the lines as geometry?
    • Devendra Badgujar
      Hello Tim Martinson
      I will check and get back to you.
    • Devendra Badgujar
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello Tim Martinson
      You will have to use ''Project to sketch'' option from the Sketch Tab. Please check attached video demonstrating the process to project lines on surface.
      Let me know if you need any further assistance.
      Regards.
      • tandama
        Devendra Badgujar this will not work for my application.
    • tandama
      How do I keep the purple lines, in the screenshot, as curves and not have them become part of the surface/solid?
      • Devendra Badgujar
        Tim Martinson
        Can you please share your geometry file with me ? I will try it at my end and let you know.
      • tandama
        Devendra Badgujar How do I share a file with you?
      • Devendra Badgujar
        Tim Martinson
        I have shared with you a Secure transfer link to upload your file. Please check it.
        Regards.
    • Devendra Badgujar
      Solution provided.
Viewing 4 reply threads
