3D Design
3D Design
Projection Issue
    • khush2511
      Hello Folks,
      I am making a study of transonic flow on a wing and following the Simcafe Fluent tutorial. Under the video shown on this link (
      ) for splitting the wing face, I am trying to make the projection of lines on wing face but projection function is showing an error. On checking the problematic geometry option, it is showing both of the lines as incomplete geometry.
      Kindly guide me how can I fix this issue?
      Best Regards
      Khushin Lakhara
      Have you got a surface or body to project onto?
    • khush2511
      I have to project it on the wing-body, for more info kindly take a go through of the shared video problem statement post.
      Maybe extend the lines? Without looking at the model (which I'm not allowed to do) you'll need to go back through the tutorial very carefully.
    • gwilliams1
      I think I am having the same problem as khush2511. When I try to project in the positive y direction, it doesn't work. When I change it to go in the negative direction, it then works. I think my direction vector is what is cause it not generate. How would I be able to fix that?
      If it's working in the negative direction hasn't it worked?
    • Sara Anwar
      Could any one know how to solve that error ?
    • Sara Anwar
      Is that will be any error if i made it in negative direction ?
      because it works only in negative direction
Viewing 7 reply threads
