October 12, 2018 at 4:50 pm
Luis
SubscriberHello everyone,
I'd like to set a mechanical simulation of a rotating (540rpm) propeller shaft of a ship: my aim is to analyze the stress induced by the vibrations to the strut that bears the bushing in which rotates the shaft. How can be done that? Which is the analysis system set that most fits to my case?
Thanks in advance for your help
Luis
October 12, 2018 at 5:40 pm
Sandeep Medikonda
Ansys EmployeeLuis,
You can either do a transient structural or a Harmonic response analysis. Please check out the following resources for some info:
Sandeep
Best Practices to post on the Student Community -
October 12, 2018 at 5:52 pm
Luis
SubscriberSandeepMedikonda thank you for your reply. So, in case of transient structural, I should just set a rotational velocity (from "inertial" menu) to my shaft and then check for the stress ? In case of Harmonic response analysis, the path is doing a static structural analysis (in which I set the rotational velocity), then a modal analysis (using as "pre stress" the previous static analysis) and then set the Harmonic response? Am I right?
Thank you in advance
Regards
Luis
October 12, 2018 at 7:49 pm
Sandeep Medikonda
Ansys EmployeeHi Luis,
Yes, see in that example that was shared we had a gravitational load which was done in static. You can just do a harmonic analysis if you want to set up a frequency load or a modal analysis if you want to just look at the natural frequencies.
Note that both modal and harmonic analysis are linear analysis and you are limited in terms of the contacts and materials you can use.
Sandeep
October 13, 2018 at 3:30 pm
Luis
SubscriberThank you so much for your help! About the rotor dynamics option, is the setting "coriolis effect" to be on or off (as default) ? Thanks -
October 13, 2018 at 4:28 pm
Sandeep Medikonda
Ansys EmployeeLuis,
"Coriolis effect" will account for the "damping” matrix contribution to the equations of the motion due to the rotation of the structure. You might want to keep that for a more accurate simulation.
Take a moment to read this section from the help.
Sandeep
October 13, 2018 at 4:38 pm
Luis
SubscriberIs it to be active for both structural and modal analysis? (since I have linked them in order to take in account the stress from rotational velocity). Thanks, yes as soon as possible I will read it. Thank you again -
October 13, 2018 at 4:51 pm
Sandeep Medikonda
Ansys EmployeeYes, use it in both:
Analysis Types Supported
The following analysis types support rotating structure analysis using a stationary reference frame:
Static (ANTYPE, STATIC)
Quasi-static analysis is used to obtain the displacements and stresses of the structure subjected to the gyroscopic moment.
Modal (ANTYPE,MODAL)
Linear transient (ANTYPE,TRANS)
For a transient analysis involving a rotating structure with a stationary reference frame, support for a start or stop simulation is available. Issue the KBC command to ramp the rotational velocity.
Harmonic (ANTYPE,HARMIC)
To include unbalance or general asynchronous rotating forces in a harmonic analysis, use the SYNCHRO command.
October 17, 2018 at 6:44 pm
Luis
Subscriberthank you very much
2120
1349
1136
461
