Tagged: 2D, ansys-student, mesh, mesh-generation, meshing
March 4, 2022 at 7:42 pm
Jad_Hanna
SubscriberI have attempted to partition the mesh around the flap as sensibly as I can and get the following error when I do so. I don’t really know why this is happening but I have tried my best.
I have attached screenshots of the error and what my mesh output looks like for your reference
March 7, 2022 at 8:21 amKeyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim." target="blank">
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Check the number of nodes on edge edge and method you have applied.
Please check if you can mesh it using tri elements.
For quad elements you will need to decompose geometry.
Please check following videos
Ansys Meshing Sizing:
Ansys Meshing: Decomposition for hex meshing:
Ansys Meshing: Meshing Methods:
Ansys Meshing: Inflation:
Regards Keyur
March 8, 2022 at 5:20 pm
Jad_Hanna
SubscriberHi Keyur I have just checked my geometry and it is error-free, I also tried meshing with tri elements and I still receive the same error. Do you have any other recommendations other than the videos?
Thanks Jad Hanna
March 14, 2022 at 5:46 am
Keyur Kanade
Ansys EmployeePlease check sizing. Try different edge sizing with tri elements.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2564
2078
1289
1106
459
